Sagan Technology Metro • View topic - Organizing The Mixer Tracks
Postby fastlanephil » Tue May 22, 2012 11:46 pm
Hello Jeremy,
After I render the midi tracks to audio I'll end up with Ports Built-In 1 through 10 or whatever in the Tracks window one after another. In the Mixer window they can be spread out among the midi instruments.
Is there a way to move them around so all the audio tracks are together one after another in the Mixer window. If not, do I need to do something so they will be grouped together in the Mixer.
Re: Organizing The Mixer Tracks
Postby Jerm » Wed May 23, 2012 11:16 am
Yes, Click the name of the mixer channel and drag left or right.
Or use the special command 'Trim outputs to tracks'
Postby fastlanephil » Wed May 23, 2012 10:18 pm
Thanks much Jeremy!
Phil
Users browsing this forum: Google [Bot] and 18 guests
