Sagan Technology Metro • View topic - color wheel
color wheel
color wheel
Postby françois » Thu Dec 22, 2011 12:22 pm
hello,
I've got some trouble with metro.
Take a very long time to open, with a color wheel.
I'm now under lion.
could someone tell me how to repare that ?
Re: color wheel
Postby Jerm » Thu Dec 22, 2011 2:43 pm
Does it only happen the first time you launch?
If yes, then perhaps you have too many plug-ins (or files in your plug-ins path).
In the previous version Metro would scan plug-ins on a different thread so the whole system would slow down but you could use Metro as long as you didn't do anything that involved a plug-in. We found this behavior more annoying than just waiting for all the plug-ins to scan.
Re: color wheel
Postby françois » Thu Dec 22, 2011 3:05 pm
in fact, it does that each time I launch metro.
I would like to delete the metro prefs, but I can't remenber where they are....
Re: color wheel
Postby Jerm » Thu Dec 22, 2011 3:51 pm
username/library/preferences
Re: color wheel
Postby françois » Fri Dec 23, 2011 7:17 am
there is no : username/library/preferences with Lion
it's the case with 10.6.8, but not with 10.7.2.... strange.....
library/preferences is now at the top of my hardisk.....
Re: color wheel
Postby Jerm » Fri Dec 23, 2011 3:51 pm
Library/Preferences is a different place.
Try this article about accessing User ~/Library Folder in OS X Lion.
Re: color wheel
Postby françois » Fri Jan 13, 2012 10:12 am
hello jerm,
I deleted the prefs, but it's still too longer to open metro.... the color wheel is always here.....
could you help me please, because it's impossible now to work...
François
Re: color wheel
Postby Jerm » Fri Jan 13, 2012 1:36 pm
You have to give me more details on what the problem is and how is it that it is impossible to work.
When Metro starts up it scans all of your plug-ins so that they show in the plug-ins window. When it is finished scanning everything should be very fast. No?
Re: color wheel
Postby Jerm » Fri Jan 13, 2012 1:52 pm
Apparently others are having problems with Lion causing their machines to slow down.
Re: color wheel
Postby françois » Fri Jan 13, 2012 2:54 pm
it appears that metro " don't answer "...
Would it be better for me to desinstall metro launch a new metro.... and map the news parameters ?
Re: color wheel
Postby Jerm » Fri Jan 13, 2012 5:55 pm
Sorry I don't understand your question.
Re: color wheel
Postby françois » Sat Jan 14, 2012 2:31 am
I made a new metro install ( without any plug-in ) but it's still the same.
What can I do now ?
Re: color wheel
Postby Jerm » Sat Jan 14, 2012 1:33 pm
The best thing to do now would be to explain the problem so that I can understand what is happening. If you explain clearly and precisely in French perhaps I can have it translated.
How can you make an install without any plug-ins? You can remove plug-ins from the plug-ins folders but that has nothing to do with installation.
Re: color wheel
Postby françois » Sun Jan 15, 2012 9:17 am
thanks jerm,
in fact, I have done a new install, delete the old prefs, and now it's ok... I can open metro easily...
François
Users browsing this forum: Google [Bot] and 8 guests
