Sagan Technology Metro • View topic - ReWire Library not installed properly ?
Postby w » Wed Nov 03, 2010 8:57 am
Error message when launching Metro.
How do i fix that problem because I do not know what application/program installs ReWire?
w
Postby Jerm » Wed Nov 03, 2010 1:15 pm
Does this happen if you run Metro 6.4.9.1?
Postby Jerm » Wed Nov 03, 2010 1:29 pm
Well it seems to work ok with 6.4.9.2 here.
I know installing reason (or the reason demo) should do it.
Postby w » Wed Nov 03, 2010 2:40 pm
Thanks for the hint.
I will have to dig up the install DVD for Reason 5 because i forgot to install it to my external FireWire drive that i have dedicated to midi/audio/video applications/projects.
w
Postby w » Thu Nov 04, 2010 12:39 pm
Jerm,
OK i installed REASON 5 and now when I launch Metro both Metro and Reason 5 are launched.
How do I stop REASON 5 from launching together with METRO ?
Walter
w
Postby Jerm » Thu Nov 04, 2010 12:42 pm
Rewire menu, "stop devices and quit rewire" or something like that.
Re: ReWire Library not installed properly ?
Postby Jamez99 » Thu Aug 22, 2013 6:23 am
well I did some research and also discuss this with some of my friends and after that we conclude the result there is possibility to change some way of working with this situation is no classes you should try an other than installing reason
Jamez99
Users browsing this forum: Google [Bot] and 15 guests
