Sagan Technology Metro • View topic - Help with the fundamentals ...
Postby Markuc » Thu May 20, 2010 10:34 am
I am sorry, new in Metro ...
Metro has very sympathetic look for me ... but is totally illogical for me.
I work as soundengineer and I use ProTools, Logic, Cubase, Sonar, Reaper, Podium and others, audiosoftware is my hobby, but in Metro I am helpless ...
For example - is possible in track window simply move (close, open, split, copy ... ) takes with mouse ?
Is possible simpy make fades and crossfades in track window ? Metro manual is very unnoticed, without images ... many basic features in Metro are time consuming for me ... exist some graphically based tutorial ?
Thank You and sorry my bad English ... :D
Markuc
Re: Help with the fundamentals ...
Postby Jerm » Fri May 21, 2010 1:32 pm
Markuc wrote:is possible in track window simply move (close, open, split, copy ... ) takes with mouse ?
I don't understand your question. You can drag regions with the mouse.
Markuc wrote:Is possible simpy make fades and crossfades in track window ?
If it is audio, make a selection and select fade or cross fade from the audio menu. If it is MIDI then you will need to use the continuous data dialog.
Markuc wrote:exist some graphically based tutorial ?
Our downloads page has a MIDI tutorial.
Postby Markuc » Fri May 21, 2010 3:39 pm
Thank you ... i am idiot ... i must more read the Metro manual ... :lol:
Markuc
Users browsing this forum: Google [Bot] and 15 guests
