Sagan Technology Metro • View topic - suddenly two of my my track faders move in unison
Postby danskemusik » Tue Mar 31, 2009 8:25 am
i am not sure what I did, but now of 4 midi tracks i have laid down, two have their mixer window faders move in unision. There is a little red light lit up beneath them. But I have not seen this mentioned. What have I accidentally done to get this and how do I undo it?
Jens
danskemusik
Postby Jerm » Tue Mar 31, 2009 9:50 am
This means that the instrument faders are grouped. This can happen automatically if the faders are assigned to the same port and channel.
If they are assigned to the same channel you will need to change the channel. Otherwise use ungroup from the special menu (or command-click the fader IIRC).
Postby danskemusik » Tue Mar 31, 2009 10:11 am
I see...that must be my error.
Jens
danskemusik
