Sagan Technology Metro • View topic - Mach 5
Mach 5
Mach 5
Postby Scoot » Tue Oct 17, 2006 1:22 pm
Does MOTU's Mach 5 run on intel, as I don't believe it's universal yet (maybe never?).
Does that mean it runs in Metro 6.3.3?
Is it reasonably quick - though I know I would be in rosetta.
Postby françois » Mon Oct 23, 2006 7:36 am
Mach 5 V 2 wil be launch at the end of the year.
not intel for instance.
Postby Jerm » Mon Oct 23, 2006 11:21 am
It is not that quick although it does work. To get it to work correctly though you must remove either the VST or AU versions first.
