Sagan Technology Metro • View topic - Recording 2 0r more Trks
Postby GSpro » Mon Aug 21, 2006 4:34 pm
Is there a way to record 2 or 3 midi tracks at once in Metro?
GSpro
Postby Jerm » Tue Aug 22, 2006 12:35 am
Yes, shift-click record-enable. If you are using a newer version of Metro you can select the MIDI input device from the 'inpsel' field of the tracks window.
Postby GSpro » Tue Aug 22, 2006 4:12 pm
Thank you very much
GSpro
Users browsing this forum: Google [Bot] and 10 guests
