Sagan Technology Metro • View topic - Another beginner
Another beginner
Postby Jerm » Thu May 01, 2008 4:10 pm
Hello Jim,
This will happen if you try run Metro while another version is already running. The preferences file is open with read/write access from the other version that is already running.
If you are sure you are not running another version then you may have a corrupt preferences file. Remove it from user/library/preferences
Postby Jim Obermeyer » Fri May 02, 2008 9:35 am
Thanks again, I still had the Metro demo installed, I got rid of it and got rid of the problem.
Jim Obermeyer
Previous
