Sagan Technology Metro • View topic - Adding Effects Using SharpGray
Postby fastlanephil » Fri Oct 02, 2015 8:23 pm
Hi Jeremy,
I wanted to know how one adds effects(verb) to each instrument using an Aux Buss when using SharpGray. I don't see a pull down menu over to the right like the other Color Schemes where you select an Aux where the effect is installed which drops the volume sliders. I've been switching back to one of the other Color Schemes when setting up my reverb because I don't see how it's done in SharpGray.
Phil Lovgren
Re: Adding Effects Using SharpGray
Postby Jerm » Fri Oct 02, 2015 9:18 pm
If you look at this picture taken from the Instantiated effects/plugs window:
The modern rack should look the same regardless of the color scheme. When one clicks on the downward pointing triangle (in this image it is directly below the yellow rack item containing U-HE-Uhbik_T) a plug-in popup menu appears where one can select any plug for instantiation.
Alternatively you can select the aux-buss in the graphic editor and use the effects popup field of the track title bar to manage the instantiated plug-ins.
Lastly, you can drag a plug-in from the plug-ins window to the graphic editor, mixer window or instantiated plug-in window to add a plug-in.
In this picture from the graphics editor:
Select an aux buss from track name popup and then select an effect (or shift-click to add) from synth plug-ins popup.
Postby fastlanephil » Sat Oct 03, 2015 12:40 am
I guess I wasn't explaining things very well. I meant when I have rendered midi tracks to audio and am working in the Mixer Window.
If I have a reverb like QL Spaces loaded in in Aux 6 I select Aux 6 from the pulldown menu above the panic button in the upper far right and the sliders for my audio tracks will drop down to zero(0) and then I can add so much verb to each audio track. I don't see that in SharpGray so how is that function accomplished in that Color Scheme?
Postby Jerm » Sat Oct 03, 2015 11:51 am
Okay, sorry I misunderstood.
In the sharpgray scheme the main volumes always reflect volume. On the upper left you can select the aux for send. So in your case select Aux 6, Then each channel has a send volume and pan, set those accordingly.
Users browsing this forum: Google [Bot] and 2 guests
