Sagan Technology Metro • View topic - OSX 64 bit?
OSX 64 bit?
OSX 64 bit?
Postby Scoot » Fri Jul 25, 2014 4:11 pm
Is Metro 7.2.4 running 64 bit in mavericks?
Activity monitor tells me it's running in 32bit, and get info doesn't have a tick box to change it.
Just bought Sampletank 3 and it's not running.......unless in standalone mode.
Re: OSX 64 bit?
Postby Jerm » Sat Jul 26, 2014 3:22 am
No. Metro is only running 64 bit on the PC. It is quite a bit of work to convert everything to objective c++. And also a lot of technologies, e.g. Quicktime has been deprecated.
There is no 32 bit version of Sampletank 3?
Re: OSX 64 bit?
Postby Scoot » Sat Jul 26, 2014 4:21 pm
No Sampletank 3 is 64 bit only.
There is a standalone version.
Can I trigger the standalone from within Metro or will the lag be too long?
Re: OSX 64 bit?
Postby Jerm » Sat Jul 26, 2014 5:21 pm
If it accepts virtual ports it might work.
Have you asked IK why no 32 bit?
Do you have a 64 bit OS on a PC?
Re: OSX 64 bit?
Postby Scoot » Sat Jul 26, 2014 9:50 pm
Well ST3 is 64 bit only and there's a few complaints about that
......all the old ST2.5 and Miroslav Philharmonik can be imported into ST3's window so every things in one place.
I'll have to look at our laptop at work see if it's 64.
Re: OSX 64 bit?
Postby fastlanephil » Mon Sep 22, 2014 11:38 pm
I just downloaded SampleTank 3 and have it working with Metro 7.2.4 using Vienna Ensemble Pro 5 as the host. For instruments samples I imported Miroslav Philharmonic into ST3 which did take some time.
Users browsing this forum: Google [Bot] and 16 guests
