Sagan Technology Metro • View topic - Windows Metro SE demo question
Postby Jer78 » Wed Apr 02, 2014 5:23 pm
Can 32-bit VSTi's be used in the 64-bit version of the Windows Metro SE demo?
The Windows Metro SE demo is 64-bit and whenever I try to load a 32-bit VSTi, I get an error message saying "unable to locate proxy DLL" or something similar.
Is there a bit-bridge or something similar?
Jer78
Re: Windows Metro SE demo question
Postby Jerm » Wed Apr 02, 2014 7:00 pm
I recommend jBridge to run 32 bit plug-ins in the 64 bit version. Metro has built in support for jBridge so that when you try to load a plug-in (and jBridge is installed) it will magically load.
However if you are using a lot of software synthesizers you will probably want to buy Metro LX or the full version.
Users browsing this forum: Google [Bot] and 11 guests
