Sagan Technology Metro • View topic - Chord Entry Method Question
No questions asked!
Postby Lytz1 » Sun Jul 19, 2015 12:28 pm
Hey Jeremy,
What is the difference of theese settings?
I know it changes Rythm Explorers behaviour pretty subsstancially ,
but what is the "rule" behind the settings?
It seems to me that normal behaves pretty melodic,
keep chord notes seems to "smooth out" the transistions
random...no clue.
And keep same bass notes... sounds like a mix of the first two,
not so melodic than normal not so "smoothed out" than the second one?
(But in general sequences tend to not "jump around the scale" that much on that setting?)
But again, no real idea, just guessing...
(See image below)
Chord Detection Stuff 1
Re: Chord Entry Method Question
Postby Jerm » Sun Jul 19, 2015 5:15 pm
Lytz1 wrote:normal
This enters the chord exactly as defined in the scale/chord dialog
Lytz1 wrote:keep chord notes
Find the closest matches for all new notes that occur from chord to chord. So for example a C to F chord change would be C1, E1, G1 followd by C1, F1, A1
Lytz1 wrote:random...
Randomly transposes notes up or down between 0, 1 or 2 octaves.
Lytz1 wrote:[b]keep same bass notes[
Same as keep chord notes but also preserve bass note I believe.
Postby Lytz1 » Mon Jul 20, 2015 4:54 pm
Alright, thanks a lot, that helps.
Return to Tips & Techniques
