Sagan Technology Metro • View topic - Midi Ports question...
No questions asked!
Postby Lytz1 » Sat Jul 18, 2015 11:07 am
Hey all,
I try to figure out how to manipulate the number of midiports per instruments.
I can only get 1 or 16 (if set to multitimbral)
I'd like however to have 4 on some instruments (like groove agent) and
8 on some others (like the spectrasonics stuff)
I am sure I had this going once, but I can't remember how I did it.
Any help here?
Re: Midi Ports question...
Postby Jerm » Sat Jul 18, 2015 2:26 pm
When you instantiate a plug-in, Metro will create 1 or 16 outputs based on the multi-timbral setting. After instantiation you can delete the unwanted outputs by selecting them (with the shift and/or command keys) in the mixer window and then delete them.
Postby Lytz1 » Sat Jul 18, 2015 2:43 pm
Aah, in the mixer window. Thanks J.
t.
Return to Tips & Techniques
