Sagan Technology Metro • View topic - Using " Shift " Function
No questions asked!
Postby françois » Tue Dec 29, 2009 2:25 pm
Hello When I use " shift " some parameters aren't shifted :
Pgm
CC 32
CC 00
could someone help me to resolve this problem ?
thanks
Postby Jerm » Tue Dec 29, 2009 3:24 pm
Programs and Bank Changes (controllers 0 and 32) when entered via the popup menus are locked so that the sound associated with a track are not changed. You can do 2 things to affect what happens to these events.
1. Manually change the start time in the event editor or
2. Option-click the left most section of the event editor to select these events. This will change them from protected to normal events and you can then freely shift them like any other event.
Postby françois » Tue Dec 29, 2009 3:37 pm
thanks jerm, I will try it
Postby françois » Tue Dec 29, 2009 3:44 pm
it's a long work.
I have to see in each track if the CC is moved or make it myself.
I want to do this before deleting time from tracks.
Return to Tips & Techniques
