Sagan Technology Metro • View topic - MOTU's MachFive
MOTU's MachFive
No questions asked!
MOTU's MachFive
Postby Jerm » Sat May 20, 2006 1:32 am
The only way I have been able to get MOTU's MachFive product to work in Metro is to remove all traces of the VST plug-in from the folder /Library/Audio/Plug-Ins/VST/
That is remove the MachFive folder. In my plug-ins folder I simply created a disabled folder and dragged the MachFive folder from the /Library/Audio/Plug-Ins/VST/ folder to the /Library/Audio/Plug-Ins/Disabled folder.
The important thing is that Metro does not find any MachFive VST plug-ins. Once this is done, the AudioUnit (AU) version of MachFive works fine.
Why this is the case? Only MOTU can answer that.
mach five
Postby françois » Mon Jun 05, 2006 10:47 am
is mach five in V2 version now or not ?
Re: MOTU's MachFive
Postby Andersan » Thu Nov 06, 2014 2:40 am
Fsi
Andersan
Re: MOTU's MachFive
Postby GSpro » Wed Nov 12, 2014 6:51 pm
Andersan wrote:The important thing is that Metro does not find any MachFive VST plug-ins. Once this is done, the AudioUnit (AU) version of MachFive works fine.
Is somebody trolling the Metro forums, Jeremy?
I think there is another somewhere.
GSpro
Re: MOTU's MachFive
Postby Jerm » Wed Nov 12, 2014 7:59 pm
Yes, his account is also deactivated.
Re: MOTU's MachFive
Postby GSpro » Wed Nov 12, 2014 8:10 pm
Jerm wrote:Yes, his account is also deactivated.
Hi Jeremy,
Did you already know about it? The one thing I don't want to do is annoy you with it. If not, there is another in the "Bugs Report" forum from "blackbee045" the very top post.
Thank you,
Adriano
GSpro
Re: MOTU's MachFive
Postby Jerm » Wed Nov 12, 2014 9:02 pm
Adriano,
Yes I monitor this stuff very closely and when I see a new member post a nonsense or copycat post I will either deactivate their account or immediately delete them.
Return to Tips & Techniques
