Sagan Technology Metro • View topic - Metro prerelease 6.3.2.3
Postby Jerm » Tue Sep 06, 2005 3:09 pm
Upgrades from 6.2 are free. All new purchases include access to this version. There is an upgrade price of $34.99 to upgrade any flavor of Metro from 6.x to 6.3.2.
Download it here:
IMPORTANT: This pre-release (Metro and Metro SE) still works under OS 9 but we are no longer providing Tech support for OS 9. This will most likely be the last OS 9 release as it is getting increasingly harder to support OS 9.
New to this version: 6.3.2.3
• New: Software Audio Thru now has the ability to send audio data through an aux buss effect chain. When any aux send is up and software audio thru is on, an additional audio packet size of latency will be added.
• New: Minor cosmetic improvements.
• New: The help tags in the graphic editor display pitch as well as time when in a MIDI view.
• New: Quantize now works when dragging audio regions. Also the note popup is selectable from the audio view to set the quantize amount.
• Fixed: Selecting 'R' in the input select for audio recording was not working properly.
• Fixed: Undo and redo now save and restore the current views properly like they used to before multiple undo was implemented.
• Fixed: There was a problem where the audio overview was incorrectly displayed after insert or delete time when multiple tempo changes existed.
• Fixed: Cue looping was partially broken in 6.3.2.2.
• Fixed: Undo was producing a small memory leak.
