Sagan Technology Metro • View topic - Metro 6.3.2.2 pre-release
Postby Jerm » Mon Aug 29, 2005 10:21 am
Upgrades from 6.2 are free. All new purchases include access to this version. There is an upgrade price of $34.99 to upgrade any flavor of Metro from 6.x to 6.3.2.
Download it here:
IMPORTANT: This pre-release (Metro and Metro SE) still works under OS 9 but we are no longer providing Tech support for OS 9. This will most likely be the last OS 9 release as it is getting increasingly harder to support OS 9.
New to this version: 6.3.2.2
• New: The Core Audio overload detection dialog only appears if the audio packet size is less than 512 and there is an option to not show the dialog again.
• New: AudioUnit plug-ins that have custom parameter display names are now shown in the graphic editor.
• Fixed: Plug-ins with more than 2 audio outputs now work correctly when placed on the rewire aux buss.
• Fixed: The continuous data dialog was creating aliasing on plug-in effect parameters when the 'scale by' option was selected.
• Fixed: A rounding error occurred in the display of certain plug-in effect parameters.
• Fixed: A buzzing sound could occur if a plug-in was bypassed on an aux buss if the plug-in had more than 2 audio outputs.
• Fixed: MIDI Export was broken in 6.3.2.
• Fixed: Loop recording has been improved.
• Fixed: Improved internal Metronome especially during cueing or loop recording.
• Fixed: If using 'Honor core MIDI time stamps', recording from external sync was not working.
• Fixed: It was possible, after closing rewire, that MIDI would stop outputting.
• Fixed: After mixing audio with tracks that contain independent track loops, it was possible that the lengths of those tracks could be erroneously changed.
• Fixed: A problem was introduced in 6.3.2 that caused audio to briefly play directly after recording was stopped.
