Upgrades from 6.2 are free. All new purchases include access to this version. There is an upgrade price of $34.99 to upgrade any flavor of Metro from 6.x to 6.3.x.
Download it here:
IMPORTANT: This pre-release (Metro and Metro SE) still works under OS 9 but we are no longer providing Tech support for OS 9. This will most likely be the last OS 9 release as it is getting increasingly harder to support OS 9.
New to this version:
• New: All MIDI tracks can now be routed to accept input from a particular MIDI input controller (keyboard).
• New: Multi-MIDI thru allows all MIDI record-enabled tracks to be routed from their input to their output. Automatic MIDI thru must be enabled for this feature to take effect.
• New: Metro now listens for AudioUnits that change their Factory-Presets.
• New: Effect are now supported when placed on the ReWire Aux buss.
• New: The jukebox will now correctly plays back high bit sizes and sample rates within SE and LX.
• New: Support for dragging samples of stereo audio files from either the left or right channel.
• New: A new dialog option for finding program names (Full Version Only). This allows you to easily search for a particular sound in your MIDI or soft-synth name library.
• New: The cue button is highlighted when loop recording.
• New: If many Core Audio overloads are detected, Metro brings up a dialog allowing you to immediate increase the audio buffer packet size.
• New: Muted Movie tracks do not play.
• New: Recent files under OS X show long file names.
• New: Changing parameters related to record looping in the Play Record Setup dialog will automatically enable the record loop setting in the transport.
• Fixed: Software audio thru was usually introducing noise at the end of every playback buffer.
• Fixed: Soft-synth compatibility improvements including better support for when the Synful orchestra plug-in is placed on an aux buss.
• Fixed: Group Normalize was not working properly on 32 bit audio files.
• Fixed: Master volume automation was not being chased properly. This could result in the wrong volume being set for MIDI or soft synths if Master Volume Automation was in use.
• Fixed: Many improvements in regard to Quicktime Movie support including eliminating a potential crash when using undo.
• Fixed: Miscellaneous minor cosmetic issues.
• Fixed: Notes are no longer eaten during the end of count-off.
• Fixed: Problem related to saving grooves for use with Groove Quantize.
• Fixed: A couple of problems when honoring core MIDI time stamps. Including offset errors when counting off and record looping.
• Fixed: Problem whereby sys-ex could be recorded even if Record Criteria had it disabled.
• Fixed: Better Core MIDI compatibility.
• Fixed: More robust loop recording compatibility. Multi-take record looping improvements when audio is being recorded.
• Fixed: A problem introduced in Tiger whereby Audio files would not import unless they were created with Metro.
• Fixed: More accurate support for 'wait for note' when doing audio recording. Because of technical issues there is still a gap of one audio-buffer-packet after a note is pressed.
• Fixed: Version numbers are more accurately printed in the plug-in window.
• Fixed: Better support for plug-ins that cannot be found when a Metro document is opened.
• Fixed: Minor problems related to changed ports and the change ports dialog.
• Fixed: A problem whereby changing the PPQ setting in MIDI setup did not always work properly.
• Fixed: A problem with the internal Metronome.
