Sagan Technology Metro • View topic - Metro 6.2.2 pre-release no longer available
Postby Jerm » Thu Oct 28, 2004 2:52 pm
Upgrades from 6.2 are free. All new purchases include access to this version. This pre-release version is now available for an upgrade fee of $14.99. The upgrade price is for upgrading any flavor of Metro from 6.0 or 6.1 to 6.2. This sale price will end when Metro 6.2.x is officially released.
Download it here:
New to version 6.2.2:
• New: Multiple Undo with user size setting in buffer preferences. Other major enhancements were made to the undo system including:
Undo tempo from the Section Event Editor.
Undo drum name drag.
Undo Clear plug-in from the Effects window.
Undo the insertion of track loops.
Undo the archiving of tracks.
Undo Audio import.
Undo MIDI file drag.
Undo multi section clear in section window.
Undo create subsection.
Undo output selection.
Plug-in editor windows are remembered and restored.
• New: MIDI Document Icon for OS X.
• New: 'wait for note' mode now works with audio and soft-synths.
• New: Optimization should improve drawing speed of audio overviews.
• New: Files dragged to the tracks window are now accepted.
• New: Plug-in editor windows are marked with their section and track location in the windows menu.
• New: Soft-synths installed after other soft-synths in an effect chain are now flagged and an error message appears.
• New: Metro now only saves program names to .ins files. The long standing reason why metro was not doing this was because there was no mechanism for storing sysex in .ins files. Sagan Technology has developed its own solution to this problem by adding a MIDI stream (MIDIS) command to the .ins file specification. We are hoping that Cakewalk with ratify this change soon.
• New: The plug-in popup, when selected on an aux buss, now shows all plug-ins not just soft-synths.
• New: The jukebox can now read iTunes information written into .aif files such as title, artist and more.
• New: Context-sensitive help can now be invoked using your local file system (OS X only). To do so you will need to download the Manual.sitx file from our web site. Unstuff it and place the resulant folder named 'Manual' in the Metro folder. Then from the help menu turn on 'local help'.
• New: Help tags can be turned off and on via the help menu.
• Fixed: When a plug-in was cleared, its automation was not.
• Fixed: Changing the tempo now moves automation with the audio.
• Fixed: When the first soft-synth in a chain is cleared it was possible that the new chain's output was not being set to the original output.
• Fixed: On some occasions, particularly after mixing or rendering audio, Metro would leave notes on in soft-synths.
• Fixed: Better stability with some plug-ins, notably VirSyn:Cube.
• Fixed: Metro was not playing back 8 bit .wav files correctly in the jukebox.
• Fixed: Metro was not playing back 8 bit .aiff files correctly in some cases.
• Fixed: There were still some cases where subsections containing soft-synths would be out of sync with audio and MIDI.
• Fixed: Miscellaneous minor display abnormalities.
• Fixed: Miscellaneous display optimizations under OS X.
• Fixed: A problem where automation was being data sent even if automation play was off in the mixer window.
• Fixed: Continuous data display of EFX automation has been enhanced.
• Fixed: Core Audio latencies are calculated more accurately.
• Fixed: multiple track paste could have failed in some rare cases.
• Fixed: multiple track paste was not always restoring the copied soft-synths properly.
• Fixed: audio overviews are drawn more accurately.
• Fixed: Subsection events contained on a muted track were, in some cases, not being triggered so that unmuting the track would not cause the subsection to play.
• Fixed: The selection is transposed correctly after certain note drag operations.
• Fixed: Preferences are now migrated into a new Metro 6 Preferences file. This solves backward compatibility problems with the old preferences file.
• Fixed: Some very old versions of Metro did not store automation correctly. Metro now detects and automatically fixes this problem.
• Fixed: A possible crash if working with bypass automation in the graphic editor and then switching to EFX automation.
• Fixed: For some unknown reason, reportedly starting with 6.2.1.7, if internal channels are allocated before audio input is selected, audio input was impossible.
• Fixed: A lock up was possible if a recent file was deleted from the finder before returning to Metro.
• Fixed: Small memory leaks.
Re: Metro 6.2.2 pre-release now available
Postby Scoot » Thu Oct 28, 2004 4:30 pm
Jerm wrote:• New: Multiple Undo
Bloody brilliant!!! Works great. Thank you Jerm and SaganTech. :D :D :D
Excellant!! Primo!! Bravo!!!
Postby Gary K. Doty Sr. » Thu Oct 28, 2004 8:59 pm
Metro continues to be one Hell of a program.
It is regretable that some people cannot look beyond the BIG 3 or 4 music
production Apps., to see just how useful and how reliable and productive
Metro 6.2 is!!
ONCE AGAIN MY HAT GOES OFF TO ALL OF THE METRO TEAM for making a great product even better !!!!!!
Thanks Jeremy and the Metro team!!! and everyone at SAGAN TECH!!!!
Gary K. Doty Sr.
Gary K. Doty Sr.
Postby Jerm » Thu Oct 28, 2004 10:44 pm
Gary,
Thanks again :)
Postby flanchec » Sun Oct 31, 2004 3:05 pm
Hello !
I'm particularly impressed by the fact that I just asked for this feature one month ago... and it's here !
Fantastic ! 8)
Vynce
flanchec
