Sagan Technology Metro • View topic - Metro pre-release 6.2.1.6 (no longer) available.
Postby Jerm » Tue Jul 20, 2004 1:30 pm
Upgrades from 6.2 are free. All new purchases include access to this version. This pre-release version is now available for an upgrade fee of $14.99. The upgrade price is for upgrading any flavor of Metro from 6.0 or 6.1 to 6.2. This sale price will end when Metro 6.2.x is officially released.
Download it here:
New to version 6.2.1.6:
• Fixed: A problem introduced in 6.2.1.3 whereby if the qualification dialog appeared upon startup, later Quicktime would hang under certain circumstances.
• Fixed: Audio monitoring was not turned on when the jukebox stopped playing leaving a stuck VU meter.
• Fixed: A problem where a popup was not popping up (OS X only) in the modify-outputs-and-busses dialog after an audio output was selected in the jukebox window.
New to version 6.2.1.5:
• New: Better compatibility with plug-ins that generate their own note or drum data, for example Glaresoft's iDrum or PowerFX's Miracle drums.
• New: If a single MIDI file is dragged to the graphic editor window it will now be added to the current section. Previously this would load the MIDI file in a new section. This does have the side effect of adding section events (tempos, time signatures) to the current section.
• Fixed: Inserting first and second endings in the notation view would cause a crash.
• Fixed: The jukebox was not playing back .Wav files correctly if their sample rates were not 44kHz.
• Fixed: Metro would quit (thanks QuickTime!) when the jukebox encountered a .M4P file (iTunes protected file) during scanning.
• Fixed: Digital audio overviews were not correct if the section contained tempo changes. This bug was introduced in a recent pre-release.
• Fixed: When a note's duration was being dragged (via shift-click) and that note was on a track that contains both MIDI and Audio, the note end time was not being displayed properly in the upper left of the graphic editor.
• Fixed: minor cosmetic problems in the graphic editor.
• Fixed: Tempo changes were not being reported to plug-ins during mixing or rendering.
• Fixed: Effect automation is now taken into account when calculating the length of a track.
• Fixed: A crash could occur if the event editor was following playback and automation was inserted via the mixer window's contextual menu.
• Fixed: Delete and Insert Time now work on plug-in automation data on a track.
• Fixed: Grids were not drawn in the graphic editor for time signature 1/4.
How to upgrade
Postby lesag002 » Thu Jul 22, 2004 9:14 am
I don't understand how to upgrade from 6.1 to 6.2. All I see in the dowload area is 6.1 build 10. How do pay $15 and get 6.2?
Mark LeSage
Twin Cities, MN
lesag002
Postby Jerm » Thu Jul 22, 2004 9:58 am
First to upgrade you must know your download login username and password (this is most likely different from the username and password used to login to this forum). Then click here to get to the store and follow the links to upgrades.
