Sagan Technology Metro • View topic - Metro pre-release version 6.2.1.3 (no longer available)
Postby Jerm » Sat Jul 10, 2004 6:17 pm
Upgrades from 6.2 are free. All new purchases include access to this version. This pre-release version is now available for an upgrade fee of $14.99. You must first have version 6.0 or greater to upgrade to 6.2. The upgrade price is for upgrading any flavor of Metro to 6.2. This sale price will end when Metro 6.2.x is officially increased.
Download it here:
New to version 6.2.1.3:
• New: Metro supports plug-ins that default to 20 outputs or less. Previously it was 16.
• New: Worked around a bug in the Audio Unit versions of Crystal, Amplitube and TRackS that would cause these plugs to crash if uninitialized and then re-initialized which is necessary to change the sample rate.
• New: The Mix dialog now defaults to the current playback sample rate and audio packet size.
• New: Metro does a better job of resolving program names for multiple instances of a single plug-in.
• New: Metro now bounces its icon in the dock when it needs attention.
• New: Metro will now start up the audio engine whenever a Soft-Synth is loaded. Previously, for example, the audio engine would be idle after Mixing audio. This provides a much better user experience as you can play notes from the plug-in at any time and hear them.
• Fixed: Metro was not setting AudioUnits to the correct mode before resetting their sample rates. This may have caused problems when Mixing audio to a different sample rate than the plyaback rate. Note that several plug-ins do not work properly when their sample rates are changed.
• Fixed: if a Sample Rate conversion was happening on a track that contained a plug-in that accepts both audio and MIDI,it was possible that audio would continue to sound after stopping.
• Fixed: Metro now detects if it is in the background better.
• Fixed: Rearranged some resources in the mix/render dialog that were conflicting with the Korg Legacy collection.
• Fixed: The display problem in Jaguar introduced in 6.2.1.1 was actually a bug in Metro. Jaguar users should see a slight increase in audio waveform drawing speed now.
• Fixed: Render was not working correctly in some cases.
• Fixed: In OS 9 the plug-ins window header was not drawing if there were no plug-ins.
• Fixed: Metro was initializing plug-ins to the old (saved) sample rate and then re-initializing them to the new sample rate. This would cause problems in plug-ins like Spectrasonics Atmosphere.
• Fixed: Mixing Audio was on rare occasions not setting the plug-ins audio packet size correctly.
• Fixed: Memory leaks.
• Fixed: The Mixer window would not display the status of mute and solo correctly for some color schemes.
• Fixed: Tracks that are both audio and MIDI were not showing audio in the tracks window.
• Fixed: Changing the output of a track was not automatically updating the plug-in field of the tracks window.
• Fixed: Some dialogs were modified for miinor cosmetic purposes.
New to version 6.2.1.2:
• Fixed: A simple patch to fix a major display problem introduced in the audio waveform optimization in 6.2.1.1 that only occurs in OS X Jaguar (10.2) and perhaps earlier systems.
New to version 6.2.1.1:
• New: Significantly improved use of CPU (as viewed by activity monitor), especially when in the background.
• New: Further Altivec (G4/G5) audio optimizations.
• New: optimization for drawing vu's in mixer window.
• New: optimization for drawing audio overviews in OS X.
• New: Whether a section's (or subsection's) longest track is looped is no longer determined by archived tracks. The longest track determines the duration of the section.
• New: Contextual Menu in the EFX window allows the user to trace inputs to and outputs from the effect or soft-synth. To use it, ctrl-click on the title bar in the EFX window.
• New: when loading documents with saved plug-ins Metro does a better job of displaying the name of the plug-in that is currently loading.
• New: Metro now defaults to auto MIDI thru on.
• Fixed: Metro was not properly configuring some AudioUnit plug-ins to multiple outputs. Multiple outs now work properly with plug-ins such as Battery and Phatmatik Pro.
• Fixed: There was a problem which could cause plug-ins output to become immediately silent instead of releasing naturally after the transport has been brought to a complete stop.
• Fixed: Count off did not work properly for Soft-Synth plug-ins.
• Fixed: It was possible in some circumstances that two effects would get set to the same cable creating some weird and undesirable sound effects.
• Fixed: Metro was not honoring the low and high controller range of the chasing dialog.
• Fixed: A bug prior to 6.2.1.1 in which chasing would not set the volume correctly because it was not being mapped through the master volume.
• Fixed: Metro no longer tries to configure Audio Units to 0 ins and 0 outs. This had no previously known bad affects but was totally unnecessary.
• Fixed: Changing the output of a soft-synth in the EFX window no longer leaves the vu in the mixer window hanging.
• Fixed: Metro was not always resolving soft-synth Program Name Lists properly. This could cause the list to be associated with the wrong plug-in.
• Fixed: a problem with introduced in 6.2 whereby Metro would crash if audio was dragged before anything was copied to the clipboard.
• Fixed: a problem whereby when drawing continuous audio data (such as volume or pan) for the first time, it would not appear or only partially appear.
• Fixed: a problem where upon drawing continuous data into an audio track, Metro would erroneously follow playback from the wrong time during the current cue iteration.
• Fixed: Metro was continously drawing the frame in the transport whether it had changed or not and this was unnecessarily using up CPU.
• Fixed: a problem whereby MIDI data was not always being copied underneath an audio selection during certain clipboard operations.
• Fixed: It was possible to hang Metro by dragging multiple audio files from the jukebox to the graphic editor and then switch to another application.
• Fixed: It was possible to hang Metro by rendering audio tracks.
• Fixed: If there were fewer than a screen full of plug-ins in the plug-in window, then after a column header sort was performed, a mouse click would occasionally select the wrong plug-in.
