Sagan Technology Metro • View topic - Metro 6.2.1.1 Pre-release no longer available!
Postby Jerm » Thu Jul 01, 2004 5:07 pm
Upgrades from 6.2 are free. All new purchases include access to this version. This pre-release version is now available for an upgrade fee of $14.99. The upgrade price is for upgrading any flavor of Metro from 6.0 or 6.1 to 6.2. This sale price will end when Metro 6.2.x is officially increased.
Download it here:
New to this version:
• New: Significantly improved use of CPU (as viewed by activity monitor), especially when in the background.
• New: Further Altivec (G4/G5) audio optimizations.
• New: optimization for drawing vu's in mixer window.
• New: optimization for drawing audio overviews in OS X.
• New: Whether a section's (or subsection's) longest track is looped is no longer determined by archived tracks. The longest track determines the duration of the section.
• New: Contextual Menu in the EFX window allows the user to trace inputs to and outputs from the effect or soft-synth. To use it, ctrl-click on the title bar in the EFX window.
• New: when loading documents with saved plug-ins Metro does a better job of displaying the name of the plug-in that is currently loading.
• New: Metro now defaults to auto MIDI thru on.
• Fixed: Metro was not properly configuring some AudioUnit plug-ins to multiple outputs. Multiple outs now work properly with plug-ins such as Battery and Phatmatik Pro.
• Fixed: There was a problem which could cause plug-ins output to become immediately silent instead of releasing naturally after the transport has been brought to a complete stop.
• Fixed: Count off did not work properly for Soft-Synth plug-ins.
• Fixed: It was possible in some circumstances that two effects would get set to the same cable creating some weird and undesirable sound effects.
• Fixed: Metro was not honoring the low and high controller range of the chasing dialog.
• Fixed: A bug prior to 6.2.1.1 in which chasing would not set the volume correctly because it was not being mapped through the master volume.
• Fixed: Metro no longer tries to configure Audio Units to 0 ins and 0 outs. This had no previously known bad affects but was totally unnecessary.
• Fixed: Changing the output of a soft-synth in the EFX window no longer leaves the vu in the mixer window hanging.
• Fixed: Metro was not always resolving soft-synth Program Name Lists properly. This could cause the list to be associated with the wrong plug-in.
• Fixed: a problem with introduced in 6.2 whereby Metro would crash if audio was dragged before anything was copied to the clipboard.
• Fixed: a problem whereby when drawing continuous audio data (such as volume or pan) for the first time, it would not appear or only partially appear.
• Fixed: a problem where upon drawing continuous data into an audio track, Metro would erroneously follow playback from the wrong time during the current cue iteration.
• Fixed: Metro was continously drawing the frame in the transport whether it had changed or not and this was unnecessarily using up CPU.
• Fixed: a problem whereby MIDI data was not always being copied underneath an audio selection during certain clipboard operations.
• Fixed: It was possible to hang Metro by dragging multiple audio files from the jukebox to the graphic editor and then switch to another application.
• Fixed: It was possible to hang Metro by rendering audio tracks.
• Fixed: If there were fewer than a screen full of plug-ins in the plug-in window, then after a column header sort was performed, a mouse click would occasionally select the wrong plug-in.
