Sagan Technology Metro • View topic - Version 6.1.0.4 pre-release no longer available.
Postby Jerm » Thu Nov 13, 2003 5:30 pm
The version 6.1.0.4 pre-release is now available.
Download it here:
This version will be offered as a free update for all 6.0 users for the time being.
New to this version:
• Complete Panther compatibility.
• New Feature: In the Mix Audio Tracks dialog there is a new button for rendering audio tracks. This will render audio or synth tracks into individual stereo tracks. This is very useful for transferring files to computers that do not have the specific plug-in needed to reproduce the output.
• Brand new (OS X only) plug-ins window. Now uses the OS X data browser. Sortable by manufacturer, name or user defined category. Specify categories by control (right) clicking.
• Revamped Program names dialog with brand new editor that uses the OS X data browser.
• There was a bug previous to this version (OS X only) where program names were not being stored properly. Every attempt has been made to fix this bug so that it is transparent to the user. It is possible in some rare circumstances that you may need to rebuild your program names. However, new to this version Program Names will follow their endpoint devices. So it is now possible to detach a device in AMS and reattach it to another port without losing your program names.
• Define silence was not working properly when the silence was at -infinity. This has been fixed. Remove silence was also not working properly when silence was defined as -infinity. This has also been fixed.
• Metro now import drum sets from .ins files. This makes it very easy to get device specific drum sets loaded. Note that Metro does not export drum sets into .ins files.
• A bug was fixed where a crash could occur when opening up a document saved with a plug-in that has no visible parameters (such as Unity).
• It is now possible to load program names for plug-ins.
• Chords in the marker dialog were not appearing correctly. This has been corrected.
• Metro now imports MIDI data from music player Quicktime documents. It also exports them. There is a bug in QuickTime where it will not always export Music Player data properly. Apple has been notified.
• Because of changes made to OS 10.3 Metro now shows all devices even if they do not have exposed receive MIDI channels. This means that 'reflect studio set up document' may not always build all of your outputs. In this case you will need to add outputs manually.
• Program changes set in MIDI through are now reflected on-screen in the graphic editor program field. This makes it easy to see which program you have selected with your keyboard controller.
• Many miscellaneous enhancements for OS 10.3 (Panther).
• There was a bug where selecting a bank in the graphics editor did not always work.
• The stereo checkbox from the digital audio dialog has been removed. Metro now remembers the last stereo setting selected from the input select column of the tracks window.
• Metro does not automate on archived or muted tracks any more. This was causing a problem when more than one track was assigned to the same output.
• Temporary movies were not being deleted properly in some cases.
Postby Scoot » Thu Nov 13, 2003 7:06 pm
This new plugins window...........
- what are you doing by ticking the box on the left side?
- is there a way to add a manufacturer to the empty spaces.
revamped Program names dialog.......
you may have to hit clear or clear all at the top to get this to reset.
then without any other ports available you can select DLSmusicdevice.
Hey Jerm you've also fixed another bug which I found by mistake.
I had a midi track with 3-4 bars of data, and I used the mouse to try and make it 2 bars and it slipped to 0. The data disappeared and reaching for the undo brought up an everlasting apple 'thinking' coloured wheel.
Now if you make a track 0 bars, the data remains.
good stuff!
Postby Jerm » Thu Nov 13, 2003 7:40 pm
Scoot wrote:This new plugins window...........
The left check box, says "Plug-in Handles its own presets internally". This means, when checked, you should probably not save any new presets as they may or may not be useful. This checkbox is useful in that it will speed the loading of certain plug-ins, especially plug-ins with a lot of presets and/or parameters. It even, in one circumstance, can prevent a crash inside a plug-in.
The manufacturer can be added (for VST plugs) simply by renaming the plug something like 'SaganTechnology-EQ'. Either the '-' or the ':' is used as a separator. Note that the ':' can not be used in Mac file names (I think).
Scoot wrote:revamped Program names dialog.......
Not sure what you mean here. Do not hit clear or clear-all unless you really know what you are doing.
Postby Paul » Sat Nov 15, 2003 9:06 am
Since the 6.1.0.4 prerelease, I keep having to qualify my copy. It doesn't ask me to do so every time I start Metro; it happens randomly. Is this a known issue?
G4, 733 MHz, OS 10.2.8
Paul
Paul
Postby Jerm » Sat Nov 15, 2003 1:41 pm
Information on this can be found here. If this is not pertinent, you may have a damaged preferences file.
Notation for version 6.1.0.1
Postby hallhenry » Sun Nov 16, 2003 10:04 pm
Hi jerm and scooterman:
I've been touring a lot and out of the "loop' on things. However, i just downloaded a new version of G4 metro, it being 6.1.0.1. So far so good.
Just a note though. I put the "aloisen" font file in the library-font folder on the hard drive, instead of the system -font folder, as instructed, since it would not accept changes to fonts. Everything is working fine and dandy.
So, do i have the most up-to-date version for my G4? I'm still using Jaguar 10.2.6 OSX.
thanks hallhenry
hallhenry
Postby Jerm » Sun Nov 16, 2003 11:19 pm
No, the newest version is 6.1.0.4
Postby Hurricane Ramon » Thu Nov 20, 2003 5:47 am
Does this stuff work on a e-Mac G-4 800mhz w/512 megs of ram ?
A song is alway new and always old if it is truly a good song .
Hurricane Ramon
Postby Jerm » Thu Nov 20, 2003 10:08 am
It does if you have Metro 6 or Metro 6 SE. Check out the demo.
