Sagan Technology Metro • View topic - Metro 6.0.7.3 Pre-release (no longer) available!
Postby Jerm » Thu Jun 05, 2003 11:39 pm
Download it here:
Changes unique to this version:
IMPORTANT: Metro Documents written with version 6.0.7.x will NOT be readable in any Metro/Metro SE version prior to 6.0.7!
• Audio Unit stream configurations are now selected properly. Formerly Metro would pick the first stream configuration and use that. Metro is now much smarter about which stream configuration to use in which situation. A stream configuration is the number of inputs and outputs an Audio Unit will use. This should correct problems with the Ritmo plug-in as well as the soon to be released Audio Units from Wavelabs.
• A change was made that produces a dramatic decrease in the amount of time to build audio overviews in some cases.
• A bug was fixed where the VU meter was not showing up if a mono audio track was record enabled and the default right input audio channel was invalid. Since it is a mono track only the left input channel need be valid.
• Added direct support for 'sowt' format AIFC files in the Jukebox window, which are 16 bit little endian. Since this is the native format for OS X CD's, metro can now load and play back these files immediately. Previously it was taking an inordinate amount of time to load them up and start playing.
• Fixed a problem where the AU edit windows would default to weird locations on the screen. Support has been added to remember edit window positions.
• A bug was fixed that caused problems when synth plug-in effects were used during off-line rendering.
• Fixed a problem where aux buss plug-ins were not fully initialized if jukebox was playing and the plug-in was reporting itself to be a synth. Since Metro now checks for plug-in inputs = 0, it is now possible to play jukebox files through a plug-in such as SFX Machine RT.
• They keyboard equivalent for Harmony has been changed to ctrl-cmd-H this frees up the cmd-H key sequence for hiding Metro in OS X.
• Cosmetic changes were performed on the set selection dialog.
You work fast
Postby sd » Fri Jun 06, 2003 10:25 am
Jerem
You are so fast. You guys are always coming out with updates every
few weeks.
sd
Postby Scoot » Fri Jun 06, 2003 4:45 pm
I don't know if thats a good thing or a bad thing. :D
