Sagan Technology Metro • View topic - Metro 7.2.3 Now Available
Postby Jerm » Mon Mar 17, 2014 4:05 pm
The upgrade price for any version of Metro 6 is $34.99. This update is free for Metro 7 users.
IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to version 6.5.2.
New to this version: 7.2.3
  • Using the input and output contextual submenus it is now possible to follow a track insert plug-in to a different section.
  • ‘Save and increment’ in the switches menu. When activated, causes file names to increment on each save. The original filename must not end in a number to work as expected.
  • For VST plug-in’s without version resources, the version number is inquired upon instantiation via effGetVendorVersion.
Fixed in this version:
  • The highlight color was not being restored when a document was opened in some cases.
  • Certain quicktime audio files packaged as ‘.mov’ would not be recognized properly in the jukebox.
  • Translucent image created when dragging files from the jukebox has been improved.
  • An error when importing an audio file would be reported twice in some cases.
  • More robustness when opening very old documents.
  • In some cases opening a document without making any changes caused the file to be marked as dirty.
  • Copying and pasting across documents now works for track inserts instantiated in a different section.
  • In some cases, Rhythm Explorer was not inserting random chords when no notes were in the selection.
  • The ‘SaganTechHostPluginInfo’ file could grow to large sizes unnecessarily.
  • Dragging plug-ins from the instantiated plug-ins window works more reliably.
  • An incorrect error message was presented when opening documents with too many sections. (LX and SE only)
  • Qualification was not working properly if the user did not have administrative access. (Windows only)
  • Filenames containing a ‘.’ would result in the default output name (for mixing or export) being incorrect. (Windows only)
  • Other feature enhancements, fixes and improved stability.
