Metro 7.2.0.65 Now Available
Postby Jerm » Wed Jan 22, 2014 2:47 pm
The upgrade price for any version of Metro 6 is $34.99. This update is free for Metro 7 users.
IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to version 6.5.2.
New to this version: 7.2.0.65
  • Help tag added for line tool.
Fixed in this version:
  • Custom popups work better when clicking and releasing right away.
  • Changing the first output of a multi-out, from the instantiated effects window, to off would silence the entire plug-in even if other outputs were still active.
  • Dragging a MIDI file to the drum editor did not recalculate the scrollable area.
  • In some cases the effect parameter automation display would be incorrect.
  • It was possible the track color swatch would be incorrect when loading older documents.
  • There was no way to specify the pitch in poly aftertouch view when ‘sharpgray’ was the selected color scheme.
  • SetChunk and GetChunk were being called even if the VST plug-in specified to not use chunks.
  • For certain plug-ins (made with JUCE) it was possible that clicking in the plug-ins edit window would be disallowed erroneously when using the off-line effects processor (Mac only).
  • It was impossible to select a track color on a track with no data or name.
  • Certain plug-ins (Dimension Pro) could turn off help tags (Mac only).
  • The metronome was not working in certain cases at high sample rates (Mac only).
  • Sample rate conversion was not working properly when the source sample rate was very low and the destination rate was very high.
  • Was not pausing and replaying wav files correctly in the jukebox if the file’s sample rate was different from the destination sample rate.
  • The ‘sharpgray’ color scheme was not working correctly without administrative permissions.
  • Some fonts were the wrong size in the ‘sharpgray’ scheme (Mac only).
  • The track zoom pane button was not responding in certain color schemes (Mac only).
  • The play bar color was wrong in certain cases (Windows only).
  • If an audio input device was set to ‘off’ the selection of input devices would thereafter not show all of the possible selections (Windows only).
  • A crash could occur in the Rhythm Explorer if drum mode was selected without ever setting the graphic editor to a drum view.
  • A crash or memory related error could occur if a new track was selected while recording Rhythm Explorer patterns.
  • Track scrolling via the scroll bar thumb was impossible in the ‘sharpgray’ color scheme (Mac only).
  • Other feature enhancements and fixes.
