IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to version 6.5.1.
Info on version 7.0 can be found here.
New to this version: 7.0.1
- • Metro LX is supported. (Windows)
• It is now possible to import multiple audio files in one step by dragging them into the graphic editor, tracks window or dropping them on the application icon.
• support for jBridge. If jBridge is installed, any encountered 32 bit plug-in in a 64 bit environment (and visa versa), will load as a bridged plug-in automatically.
• Mixer window can now be floated (switch menu) for better multi-monitor support. (Windows)
Fixed in this version:
- • When editing subsection in real time, some changes would not be noticed until playback was restarted.
• Output ports in the define output dialog and in the mixer window were not being shown correctly in certain cases depending on the scope.
• Expanding subsections would not assign and create the correct mixer channels if multiple tracks were assigned to a soft-synth track insert within one of the subsections.
• ‘Trim outputs to Tracks’ was erroneously removing outputs that had plug-ins instantiated on them.
• Metro LX was not allowing 32 bit audio output to be selected in the ‘Mix or Render tracks’ dialog.
• A crash could have occurred when using the spray paint tool into a drum view.
• The newer spray paint modes have been enhanced to better work with drum views.
• Help tags were showing unhelpful information during drags. (Windows)
• A possible crash could have occurred if a USB device was plugged or unplugged during the qualification dialog. (Windows)
• Several other bug fixes.
