Sagan Technology Metro • View topic - Metro 6.5.1 Released
Postby Jerm » Sun Apr 15, 2012 1:34 pm
All new purchases (since Jun-2007) include access to this version. The upgrade price for any version of Metro 6.x before 6.4 is $34.99. Upgrades from 6.4.x are free.
IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to version 6.5.1.
New to this version: 6.5.1
    • Metro is now also a Windows 64 bit application. The 64 bit version was completely rewritten to not require QuickTime. It includes full mutli-core support and custom optimizations for SSE.
    • Ripple editing is now supported with the use of the option key (alt key for windows). e.g. Cmd+Option+V will insert time before doing a paste for the length of the data on the clipboard. Alternatively you can hold the option key when selecting delete, cut or paste from the edit menu.
    • Spray scale draw mode is a new mode of the spray paint tool which allows easy entry of riffs in a selected scale by simply clicking and dragging in the graphic editor. The duration can be changed on the fly and swing is fully supported.
    • When entering numeric data in the graphic editor’s note edit dialog, floating point values are accepted in the bar, beat, duration bars and duration beats fields. e.g. you may enter 3.5 for the bar field to set the note to trigger in the middle of the third measure.
    • The home, end, page up and page down keys are now supported in the plug-ins window.
    • Metro SE users can now output audio in hundreds of additional formats using QuickTime.
    • The port change dialog has a new checkbox ‘conform out of range audio outputs’ that, when unchecked, lets you retain your track input selections in case you have changed the output device temporarily.
    • Woah is a new feature (similar to exposé) that allows all of the child windows to be visibly shrunken so that you can easily switch between windows. There is a new preference tab whereby you can select the options best for you. (windows only)
    • Metro read and writes FLAC files. FLAC is a lossless compression audio file type. (windows only)
    • The 32 bit version of Metro is now “Large Address” aware so it can allocate up to 3 (32 bit systems) or 4 GB (64 bit systems) of memory. For this to work on 32 bit operating systems you must enable the 3 GB switch. (windows only)
    • Support for media keys, e.g. rewind, play/pause, skip forward, etc. (windows only)
    • Many optimizations.
Fixed in this version:
    • Loading a document with a missing plug-in will show the name of the missing plug-in, if possible.
    • Initially upon recording, especially under the Lion OS, a long delay would occur.
    • Many fixes and enhancements to the notation window.
    • A crash could have occurred in the remote control window when selecting an input device.
    • Independent track loops were not expanding correctly when expanding subsections.
    • Swing is now ignored when quantizing tuplets/triplets.
    • Improved VST support.
    • In rare cases ‘expand by channel’ could have caused a crash.
    • In rare case it was possible that a full sequence paste would not paste 100% correctly.
    • It is now possible to move around project folders and have them still open without errors under windows.
    • The duplicate command replaces instead of merging data.
    • To conform to operating system standards, Metro will now auto-save the current Metro document when shutdown or logout is selected by the user. Upon re-launch Metro will ask if the user would like to reload the auto-saved document. (windows only)
    • The set cue, restore cue and justification menu items were not doing anything. (windows only)
    • In certain cases re-qualification was asked upon every launch of Metro. (windows only)
    • Remote Control windows system exclusive dialog is now implemented. (windows only)
    • Many other bug fixes.
