Sagan Technology Metro • View topic - Metro 6.4.9.2 Released
Postby Jerm » Tue Nov 02, 2010 12:45 pm
All new purchases (since Jun-2007) include access to this version. The upgrade price for any flavor of Metro 6.x before 6.4 is $34.99. Upgrades from 6.4.x are free.
IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to Metro/Metro SE version 6.4.9
New to this version: 6.4.9.2
    * This is the first version that has been compiled cross platform from the same sources.
    * Import Lyrics file option allows the importation of lyrics as lyric markers. The lyrics are automatically aligned to notes on the current track. Lyric markers can also be re-aligned by right-clicking and dragging a lyric marker to the correct location. All other lyric markers on the track are then aligned to notes accordingly.
    * New option for selecting the marker type (Lyric, Marker or Copyright) in the marker edit dialog.
    * New option added to the Duration Dialog for scaling duration.
    * Chord quantize added to quantize dialog allows user to quantize chords without changing the relative positions of the notes inside the chords (Full version only).
    * Step duration and options (triplet, dot, etc.) now saved with Metro document.
    * Limited support for VST parameter display mapping since few to no plug-ins support it.
    * New dialog box (windows only) detailing timing info on why Metro stopped when 'strict plug-in profiling' option is selected.
    * New plug-in option 'Resume Before Progam Change' required for some GSI plug-ins (like KeyPerformer) to behave.
    * Help tags (new for windows only).
    * New drums are automatically added when notes are entered and the track is in a drum display mode.
    * New option for automatically starting automation record when record is pressed, in the record setup dialog.
    * Missing plug-in are not removed upon instantiation of a new plug-in, so that one can use the change ports dialog to assign all of the other tracks in a multi-timbral setup.
    * New option for showing 'all file types' in the open dialog. This makes it easier to open cross-platform documents that do not have the correct Mac file type or Windows file extension.
    * Mix file type and sample bits are now saved from the mix/render tracks dialog.
    * A couple of new items have been added to the track contextual menu.
Fixed in this version:
    * Support for Mac OS X 10.3 has been restored.
    * Vastly improved windows multi-processor support.
    * Vastly improved handling of what happens when a plug-in is pasted across documents.
    * Recalculates track positions correctly when the loop icon is toggled in real-time.
    * A crash could have occured after real-time audio transpose.
    * A crash could occur depending on remote control display settings.
    * Improved handling of 32 bit little endian audio files.
    * In some cases Aux VU's were not updating in the mixer window.
    * The factory metronome could get unexpectedly muted or could sound at the wrong time under certain circumstances.
    * Improved defaults in the Port change dialog.
    * Many improvements to non-ASIO windows audio, including external MIDI synchronization improvements.
    * Playback looping is consistent now when two or more tracks have the same length and one is looped and the other is not looped.
    * Switching between jukebox and transport playback improved.
    * Metro document was being marked changed in some cases when it was not.
    * Increased the space before the time in the list editor making event selection easier.
    * When an ASIO device was selected, Metro was producing an audio glitch on stop in some cases.
    * During the loading of a Metro document, if a missing plug-in was part of a plug-in chain it was possible that the existing track's plug-in automation could be assigned incorrectly.
    * Master VU clip indicator did not light in certain cases when it should have.
    * Many other bug fixes and feature enhancements.
