Sagan Technology Metro • View topic - Metro 6.4.9 Released
Postby Jerm » Sun Apr 25, 2010 3:16 pm
All new purchases (since Jun-2007) include access to this version. The upgrade price for any flavor of Metro 6.x before 6.4 is $34.99. Upgrades from 6.4.x are free. You must have a 6.4.x license to get access to the windows versions of Metro.
IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to Metro/Metro SE version 6.4.9.
New to this version: 6.4.9
    • First windows compatible version including cross platform file compatibility.
    • Program names are automatically saved when exiting the program names dialog.
    • A fix providing compatibility for MeldaProduction plugins.
Fixed in this version:
    • A hang could occur if Metro was started by double-clicking on a document.
    • Importing an old drum set document into the Intel version could cause a crash.
    • A crash could occur in rare instances when a new track was created.
    • A crash could occur when dragging a plug-in from the effects window while the transport is engaged.
    • The real-time arpeggiator was not handling ties correctly in some cases.
    • Auto-assignment of bank and program from MIDI data is improved.
    • Change ports would occasionally not change virtual instrument audio ports.
    • Trigger MTC sync now works properly.
    • Although not visible, the graphic editor would continuously refresh in certain situations.
    • In some cases plug-in data would not be restored properly upon document reload.
    • A crash could occur in rare cases if a document written by Metro was read by SE or LX.
    • It was possible that a lockup could occur when opening a bundle file.
    • Opening an old documents was not setting the graphic editor vertical scale property properly.
    • Not all of the help menu items were functional properly on intel macs.
    • The default for newly created outputs is to not reset Modulation (controller 1) on playback.
    • If the switch 'edit notes in selection' was not checked, recording could be erratic.
