Sagan Technology Metro • View topic - Metro 6.4.7 now available
Postby Jerm » Fri Dec 26, 2008 7:55 pm
All new purchases (since Jun-2007) include access to this version. There is an upgrade price of $34.99 to upgrade any flavor of Metro 6.x before 6.4 to 6.4.6. Upgrades from 6.4.x are free.
For a limited time get a free Modelonia with certain purchases in our store. For details click here.
New to this version: 6.4.7
    • Plug-ins names and locations are now contained in the editor window's title bar and windows menu.
    • Section event window has a new, more OS X like, look.
    • Most windows can now be live resized.
    • New plug-in parameter lets user choose the Edit windows preferred user interface, carbon or cocoa, if plug-in provides both.
    • More accurate tracking of the pitch bend wheel in the keyboard window.
    • The note and select note colors are now saved with the Metro document.
    • .AIFF files written with a type of 'FL32' are now correctly interpreted as 'fl32' (32 bit floating point format).
    • Subsection event edit dialog now contains an edit button to go directly to the subsection.
Fixed in this version:
    • Rewire functionality has been restored.
    • Core Audio support improvements especially after sleep.
    • Minor enhancements to drag and drop.
    • Improved tracking of default drum sets.
    • Muting/Soloing of frozen tracks was not working correctly.
    • The glitch dialog is back.
    • Plug-in searching is improved.
    • An error message is presented if the user tries to save a scale or chord starting with a '-'.
    • Clearing outputs while playing could leave vu's meters connected to wrong outputs.
    • In some cases chasing master volume would not work correctly.
    • Changing presets via external MIDI controller was not updating preset display in the graphic editor window.
    • Certain color schemes have been fixed.
    • Restore outputs could lead to a crash if plug-in was instantiated on an aux buss.
    • Undo of a MIDI file drag is improved.
    • Chord mode honors swing setting,
    • Fast forward works regardless of priority setting in digital audio dialog.
    • The keyboard window no longer erroneously intercepts keys from the plug-in or section event editor windows.
    • Dropping subsections into the graphic editor are no longer quantized to the bar level. They are now quantized to the selected quantize value.
    • Fixed minor cosmetic issues.
    • A crash could occur after opening very old Metro documents.
    • Improved Cocoa plug-in edit window support.
    • Pressing play from fast forward mode now correctly cancels fast forward mode.
    • Certain problems with VI's in subsections have been addressed.
