Sagan Technology Metro • View topic - Metro 6.4 Pre-Release now available
Postby Jerm » Thu Sep 06, 2007 3:57 pm
All new purchases (since 06-2007) include access to this version. For Metro 6.x users there is an upgrade price of $34.99 to upgrade any flavor of Metro 6.x to 6.4. Upgrades can be purchased here.
Anyone who has upgraded after June of 2007 and does not have a valid 6.4 serial number should contact support to obtain one for free!
New to this version: 6.4 (over 50 new features!)
• Mastering. A chain of plug-ins can now be placed on the master causing all tracks and aux busses to process through the chain before being sent to the final stereo output. In the full version of Metro there is now a Master track selection from the tracks popup. The master track has a settable duration, can be looped and can be muted. Muting the master track causes the effects chain to be bypasses which can be useful if you want to addition a recently rendered mix to a track. If an effect is placed on the master buss, the master VU now displays the actual audio signal level instead of simulated audio+MIDI level.
• Side Chains. Metro will now send track audio output or aux buss output to multiple plug-in inputs. Plug-in inputs can be specified by control-clicking the title bar in the effects window and specifying the appropriate source audio. If post is selected the data will be send to the plug-in post fader otherwise it will be pre-fader. For aux buss sources the source is pre-fader only if the aux is feeding data to a lowered number aux buss otherwise it is post fader.
• The number of plug-in's audio inputs can be selected in the effects window (AU only).
• Aux busses can be looped, have a settable duration and can be muted in the graphics editor (full version only). Muting an aux buss will mute the effects chain on that buss.
• The last selected audio sample rate and sample bit size is now saved and restored with the audio device.
• Real-time display of MIDI notes while recording. Since the data is immediately moved directly to the track this feature results in an improved loop recording experience as well.
• Multiple effects in effect chains can now be selected.
• Dragging plug-ins from the plug-ins window to the graphic editor, tracks window or mixer window is now possible. This makes it possible to convert an aux buss plug-in from a track insert and visa versa.
• Strict profiling of plug-ins option in general preferences. This causes Metro to create a report of the timings used by various plug-ins. This report will appear in the system console. This option, when enabled will cause Metro to stop playback if a plug-in uses too much CPU time.
• Effects window GUI rack is complete with new 'Del' (delete) buttons. This new GUI is switchable and can be turned off from the effects window contextual menu popup.
• Effect window plug-ins rack color can be specified by control-clicking the name in the effects window. Colors default to the corresponding specified category in the plug-ins window.
• Effects window contextual menu item 'show in plug-ins' finds the currently instantiated plug-in in the plug-ins window.
• Effects window now has a down pointing triangle allowing the direct instantiation of a plug-in.
• Effects window now auto resizes when a plug-in is inserted or deleted.
• Remote control has been vastly improved and adds support for Frontier Design's AlphaTrack device. Among many other improvements, modes have been added for mutually exclusive applications as well as control over the display window. The following are new remote control actions:
Current track's output volume, Current track's output pan, Pitchbend for output, convert MIDI to computer keystrokes, Timeline position, Play Automation Enable, Record Automation Enable, Next Window, Set Mode, Set Effects Number, Set Effects Parameter Number, Set Track Effects Parameter, Aux Send Volume, Aux Send Pan, Aux Select, Load Plug-in, Master Volume, Timeline Shuttle.
• Multiple Remote Control presets can now be selected by holding the shift key while selecting a preset.
• Undo restores the size of the effects window.
• The LX version now supports bit rates up to 32.
• Mixing audio tracks now handles master volume automation. When freezing the master volume is set to max and master effects are bypassed.
• The last used tempo is saved and then restored when Metro restarts.
• Audio and Aux Send volume are now displayed in dB within the graphic editor window.
• Outputs are automatically added when expanding by channel.
• Clicking on a drum name in the drum editor now always plays the drum note.
• When recording new material on a track the playback bar follows the track record position.
• Shifting of continuous data with the arrow keys in the graphic editor is now possible.
• Aux send volume and pan views are now selectable for plug-ins in the graphic editor.
• Support for hot-plugging audio and MIDI devices.
• Inserting notes using the vertical keyboard of the graphic editor will use the current playback time during record.
• Markers are now drag-able in the graphic editor.
• If the last selected audio device is no longer available Metro brings up the audio device setup dialog upon start up.
• Metro now correctly saves and restores the currently selected Metronome audio port.
• Copy markers as chapter text from the markers window popup.
• Contextual popup menu in the sections window adds two new options. Clear and add. The add functions provides a way, for the first time, to add sections to the section window beyond the default without having to import multiple MIDI files.
• Plug-in editors are now completely closed when their window is, unless the control-key is held down.
• Add new outputs now assigns the first newly created output to the track.
• The Mixer contextual inputs menu now shows the jukebox output.
• New contextual master fader menu allow simple creation of a master volume fadeout which works on the current selection.
• Sample accurate on-the-fly recording.
• Jukebox meta data (e.g. name, artist, etc.) are extracted from Quicktime audio files.
• Several menu items have been added to the track contextual menu.
• Rescan button added to the digital audio setup dialog box. This will re-scan for devices recently added (e.g. Firewire USB).
• The last selected plug-in parameter displayed in the graphic editor is now remembered for each plug-in instance.
• The shift-page-up, '<', Shift-page-dn, and '>' keys scroll the graphic editor without the use of a mouse.
• Manufacturer names are now automatically extracted from VST plug-ins after they are instantiated.
• Intel SSE optimizations.
• The maximum number of supported inputs and outputs for VST plug-ins has been increased to 24.
• Ultra Rhythm Explorer has a new popup to specify track type.
• Additional information has been added to effects window contextual menu "get info" command.
• Duration dialog adds the option to scale durations from a starting percent to an ending percent.
• Duration dialog adds the option of trimming overlapped notes leaving a user specified gap.
• Program names for Synapse Hydra plug-in included.
• Drum set definitions for FXpansion GURU and XLN Audio Addictive drums included.
Fixed in this version:
• Vastly improved real-time audio support. Many audio operation now do not need to stop the audio engine before proceeding.
• Lock-free threads for audio recording.
• Better detection and handling of malformed MIDI files.
• Undo was not always restoring the selection correctly.
• Better handling of zooming (green '+' button) of windows.
• Improved displays.
• Better finding of audio files when moving bundles from different computers.
• Dragging a MIDI file to the graphic editor or tracks window was not placing markers, and other MIDI meta events at the correct time.
• In certain cases importing a MIDI file would destroy the entire undo history. MIDI file import is now undoable.
• MIDI file time signature are now ignored when dragging MIDI files in place to the graphic editor.
• Sometimes importing a MIDI file would not set the number of measures correctly.
• After importing a MIDI file the current section was not always being selected.
• Using the selection filter could have caused a crash.
• Many menu items are now selectable while playback commences.
• Undoing an expand by channel works better.
• Expand subsections was not working correctly when selected from the graphic editor.
• The resultant track length was not being calculated correctly, on expand subsection, when the parent subsection's track was looped.
• Using the scroll wheel to scroll an unselected pane in the graphic editor would sometimes flash the program field.
• Better support for mono audio input devices.
• Pasting of markers was not working quite right in certain cases.
• Remote control was not working if the graphic editor was in step entry mode.
• Works around a IK Multimedia Sampletank 2.2.2 problem whereby they changed their VST plug-in signature.
• Better latency compensation support for devices like Access Music's Virus TI.
• In certain cases a track could become silent after pasting data.
• Improved loop recording.
• Selected song building loop record mode was having an adverse affect on punch-in recording in certain circumstances.
• A crash could occur if a document was opened where notation was previously open but now is not.
• A crash could occur when using the new version of IK Multimedia's Sonik Synth 2.
• A crash could occur when very long marker names were used.
• A crash could occur if an AU plug-in tried to update its factory presets (e.g. CheezeMachine).
• Many new OS X compliant dialogs. Almost every dialog has been rewritten.
• Better VST 2.4 support.
• Miscellaneous other bug fixes.
• Support for OS X window groups feature for plug-in editors. This fixes a minor compatibility problem with KeytoSound Nexsyn.
• In certain cases undoing an operation would not properly restore the selection.
• Better transpose results with the from/to scale options.
• Shifting MIDI continuous data in the graphic editor with the arrow keys now works.
• It is now possible to view MIDI data on frozen audio tracks if any exists.
• Dragging files from the finder or other applications works more reliably.
• Dragging a single MIDI file while playing was causing very strange and unpredictable behavior.
• Better support for audio devices with only a single mono input.
• Groove quantize was not working properly in some cases.
• Changing the sequence length while playing could cause the metronome to mess up.
• Track VU meters were not being set properly to stereo or mono in some cases.
• The Apple DLS MusicDevice's reverb button has been removed since reverb amount can be specified in the editor.
• Dynamically created program name lists were errantly being disposed of in certain cases.
• A plug-in's default preset name was not properly being restored when a Metro document was re-opened in certain cases.
• Worked around a problem where IK Multimedia changed the signature of Sampletank 2. This allows older documents to load properly.
• Automation works more reliably.
• Audio play through works more reliably.
• The data display was not automating properly when an aux page was selected.
• Routing of audio data from aux buss multi-outs works more reliably.
• Automation data was getting messed up in certain cases if the sample rate was changed.
• Copying and pasting automation data from aux busses works more reliably.
• Fading a 32 bit float audio file was unnecessarily clipping.
• Mutes and solos in the mixer with soft synths were not working quite right.
• Enabling the loop icon during playback would sometimes make soft-synth tracks start playing the loop at the wrong time.
hotmail issue
Postby fastlanephil » Tue Sep 11, 2007 8:55 pm
The upgrade notice was put in my hotmail junk folder.
Phil
Postby Jerm » Tue Sep 11, 2007 9:36 pm
You must have some kind of filter there. No?
hotmail issue
Postby fastlanephil » Wed Sep 12, 2007 12:24 am
Yes, there is a filter and it sort of works. I have to constantly educate it.
Phil
