Sagan Technology Metro • View topic - Metro prerelease 6.3.2.4 now available
Postby Jerm » Mon Sep 26, 2005 11:50 am
Upgrades from 6.2 are free. All new purchases include access to this version. There is an upgrade price of $34.99 to upgrade any flavor of Metro from 6.x to 6.3.2.
Download the prerelease here:
http://www.sagantech.biz/downloads
IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to Metro/Metro SE version 6.3.2.
IMPORTANT: This prerelease (Metro and Metro SE) still works under OS 9 but we are no longer providing Tech support for OS 9. This will most likely be the last OS 9 release as it is getting increasingly harder to support OS 9.
IMPORTANT: This is a prerelease, meaning it has some bug fixes (and possibly features) that were deemed important enough to be released before it could be rigorously tested.
New to this version: 6.3.2.4
• New: Metro no longer limits its compensation of plug-in latencies to audio packet sizes. Latency compensation is now sample accurate. However for technical reasons, Metro will still not compensate plug-in latencies on aux busses.
• New: A check is performed for audio input selections that out of range and a message is presented if this occurs. Previously an incorrect error message would occur after trying to record. The input select could become out of range if an audio port was changed.
• New: Support for AU's new metering parameter such as the one in Apple's peak limiter in Tiger (10.4).
• Fixed: A recent prerelease introduced a problem with USB audio devices such that audio recording would produce huge and incorrect latencies. This problem has been corrected.
• Fixed: a crash could occur when mixing or rendering a 24 bit source audio file to 16 bits and the sample rate was less than 64k.
• Fixed: A hang could occur if the user selected modify outputs and busses without stopping in certain rare circumstances.
• Fixed: Plug-in latencies were calculated incorrectly when more than one plug-in in a given plug-in chain reported latencies greater than zero.
• Fixed: The jukebox had a problem parsing artist names and album names from the directory path when the path was a volume (e.g. an audio CD).
• Fixed: If presets were mapped to programs for a given plug-in and program changes occurred within a track, the presets were selected at the wrong time when mixing/rendering.
• Fixed: In rare circumstances, software audio through was not always being enabled properly.
• Fixed: Parsing audio files by selecting a jukebox folder was not working properly when in certain cases.
• Fixed: Recording multiple MIDI tracks from different sources may not have been allocating the correct amount of memory.
• Fixed: If multiple MIDI tracks are record enabled and one is switched to audio some weird problems could occur.
• Fixed: When recording while synced to an external clock source the first few events were not always being recorded.
• Fixed: When waiting to record while synced to an external clock source the record button was not flashing appropriately.
• Fixed: AUDIO + MIDI tracks were not recording audio.
• Fixed: Tempo changes were not always occurring properly the first time upon playback if there were audio tracks (or Soft-synths) and the sync was set to internal in the transport window. The easy work around, setting the sync to audio, is now uneccessary.
