Sagan Technology Metro • View topic - Metro 6.3 pre-release
Postby Scoot » Sun May 15, 2005 5:49 pm
cookies on?
Postby Adrian Delso » Mon May 16, 2005 1:54 am
I'll look in the Junk Mail blocker. I'm using Mac OS X.3.3. The first email, with the number and a password produced a "Junk Mail"? query, which I switched off, so the next one should have got through.
I'll sort it today, then I'm going to be posting in every Forum, until I get the hang of Metro. You have been warned! :lol:
Adrian Delso
Postby Scoot » Mon May 16, 2005 2:04 am
Adrian Delso wrote:I'm going to be posting in every Forum, until I get the hang of Metro. You have been warned! :lol:
Shame I'm not in Tiger or the forum can't be spotlight'ed so I can point you to the answers. hehehe.
It's always a giggle to see such a wild looking avatar panther in trouble.
Maybe you need the battersea cat's home? :lol:
Postby Adrian Delso » Mon May 16, 2005 5:47 am
Miaow!
Adrian Delso
Postby Jerm » Mon May 16, 2005 10:52 am
Adrian Delso wrote:I'll look in the Junk Mail blocker. I'm using Mac OS X.3.3. The first email, with the number and a password produced a "Junk Mail"?
We did not receive a request for a qualification so you will not receive an email. It looks to me like your default web browser configuration is set wrong. Go to Safari, preferences, and make sure your default web browser is set correctly.
Postby Adrian Delso » Tue May 17, 2005 5:40 am
I'm not using Safari and when I went to look for it yesterday, a Search failed to turn up the app. I'll see if I can download it, if necessary, but presumably I can reconfigure Internet Explorer?
Adrian Delso
Postby Scoot » Tue May 17, 2005 5:46 am
Adrian Delso wrote:but presumably I can reconfigure Internet Explorer?
When you are requesting the name for metro, metro launches your default browser and goes to the sagan site. Do you have one set???
Is this the problem?
(I assume it would be set in the system prefs under Internet -> Web).
Postby Adrian Delso » Tue May 17, 2005 8:06 am
When I reinstalled Panther, I didn't check the automatic connection box in System Prefs>Network. Der. :oops:
Adrian Delso
This software is brilliant!
Postby Adrian Delso » Wed May 18, 2005 8:35 am
As you may have guessed from this and other threads, I am not the most handy person when it comes to using DAW software, but I have just put down a bassline, clicktrack (using dls10) and a vocal, as easily as using a cassette recorder.
I then looked through the File dropdown, picked Mix and Render (lucky accident) and bounced the whole lot down to a memory stick, carted it up to my PC (faster Internet connection) and sent it to two chums in the USA for guitars and drums to be added.
More than just the ease of use, which is in a class of its own, the quality was excellent. The only thing I have changed in my normal recording setup is the software, yet the result was clearer, less muddy and subjectively brighter over identical monitoring gear, than comparable results with another better-known product, beginning with L. :wink:
Thank you, Jerm.
Adrian Delso
Re: This software is brilliant!
Postby Scoot » Wed May 18, 2005 2:52 pm
Adrian Delso wrote:The only thing I have changed in my normal recording setup is the software, yet the result was clearer, less muddy and subjectively brighter over identical monitoring gear, than comparable results with another better-known product, beginning with L. :wink:
Thank you, Jerm.
So how do you convince others? :)
I used to say PC's were made to keep idiots off Macs, but that logic doesn't help Jerm continue to improve a great app.
If you ever get a real terrible mix from rendering VSTi's, then up the render from 16 bit to 24 bit.
Always pays to do a small selection first to hear how it sounds. :wink:
Postby Jerm » Thu May 19, 2005 2:34 pm
Adrian Delso wrote:Thank you, Jerm.
You are entirely welcome. :D
Postby sseaton » Thu May 19, 2005 10:33 pm
Jerm wrote:Did you try simply deleting the .sit extension from the name?
Yes... I already did this, and everything worked fine. I'm not sure why an extra file extension was added to my download.
sseaton
Previous
