Sagan Technology Metro • View topic - Toolbar "Help" menu -Metro SE 6.3.2.3
Postby Chris » Thu Sep 15, 2005 7:10 am
Metro SE 6.3.2.3
If "Local Help" is selected in Toolbar Help menu
Both "Metro Online Help Centre" and "Online Manual" give error message "-43 file not found"
When it is deselected, "Online Manual" is OK, but "Metro Online Help Center" brings up a blank page with the URL www.sagantech.biz/support/help.htm
Same in Safari and Firefox
If Local help is the same as context sensitive help, it is accessible using the keyboard shortcut = shift/ command/forward slash
Tested on both computers
Chris
Chris
Postby Jerm » Thu Sep 15, 2005 8:20 am
Local help will only work if you install the local help available from our downloads page by downloading the online manual and placing it in the correct place.
As for the other problem I am looking into it....
Postby Jerm » Thu Sep 15, 2005 8:43 am
The second problem has been fixed. I guess this was broken after a recent web site update. Thanks.
