Sagan Technology Metro • View topic - export midi file problem
Postby Scoot » Thu Aug 25, 2005 5:33 am
Import or have midi data in metro
goto FILE / Export midi file....
choose either type 0 or type 1 (doesn't matter which)
save it
Get info - document created is 4k on disk (54 bytes) and does not play
(is it zero in length and the 54 bytes is the icon or something?)
Using 10.2.6 and Metro 6.3.2.1
NOT a problem in 6.3.1.1 which tested just fine I'm sorry to say.
Postby Jerm » Fri Aug 26, 2005 10:19 am
Yes. This is a very serious bug. We will have another update 6.3.2.2 soon to address this. It turns out that a minor change screwed up the MIDI file export system that had to be made to accomodate the multiple input recording. Thank you for finding this. :oops:
