Sagan Technology Metro • View topic - Metro 6.2.3 won't record soft synths
Postby fastlanephil » Wed Jan 26, 2005 1:53 am
I installed Metro 6.2.3 and did some editing and mixing down. Everything worked fine. Then I loaded an instrument into ST2 or GPO or tried NI's B4 and instead of being able to record I get this alert message.
"The core audio driver returned either an invalid or null audio stream."
The stop button then starts to flicker a bit. Metro 6.2.3 crashed once also. When I use the previous version it records fine. I have energy saver at "Highest".
Before I upgraded to Metro 6.2.3 I installed Apple's latest security update that came out today and then repaired permissions.
iMac G5 1.8ghz.
Postby fastlanephil » Wed Jan 26, 2005 2:25 am
Metro 6.2.3 records with built-in audio but not when using the Tascam US-122. I Just tried the M-Audio Transit and i'm having the same problem with it also. I keep getting that same alert message.
Postby Scoot » Wed Jan 26, 2005 2:52 am
>New: If a core audio device returns an invalid stream
>while recording Metro now stops.
So what's the definition of an invalid stream?
In your particular setup was everything on and awake before Metro was launched?
I used to have problems with having midi in running but midi out offline.
A shutdown and left for a minute and then a startup kicked it back into action. If I was ever needing to fault find, this shutdown tactic is my first step.
Postby Jerm » Wed Jan 26, 2005 10:10 am
Also try changing the Metronome from internal to Metronome. This seems to be a problem related to internal ports.
Postby fastlanephil » Wed Jan 26, 2005 11:11 am
I changed the metronome to metronome from internal and it worked fine with the M-Audio Transit. When I hooked up the Tascam US-122 and I couldn't select any third party plugins. The Apple soft synth would always show up. I then selected the Tascam US-122 in the metronome and saved Metro prefs and it looks like every thing is working right again. :)
Thanks for the help.
Postby Jerm » Wed Jan 26, 2005 4:12 pm
I tried plugging in my USB quattro but I still could not reproduce this problem. If someone can give me more details I would like to investigate this further.
For example, what OS are you running? What version of Quicktime?
Postby fastlanephil » Wed Jan 26, 2005 7:07 pm
Jerm,
I'm using OSX 10.3.7 and QT 6.5.2
I started tossing questionable plugins and finally got down to Native Instrument's B4 Demo and it look's like it was the problem because now I can load and play every thing with metronome selected in the metronome when using my Tascam US-122.
Postby Jerm » Thu Jan 27, 2005 2:05 pm
I have recently discovered the source of the problem and while it only rears its ugly head seldomly and only in certain situations, it does appear to be a problem with Metro that will be addressed in the next (pre)release.
