Sagan Technology Metro • View topic - Levels column
Levels column
Levels column
Postby françois » Sat Jan 15, 2005 1:22 am
The levels column selection in the tracks windows is not saved.
i have to select it each time I open metro.
Postby Jerm » Sat Jan 15, 2005 2:43 am
This has been recently fixed.
