Sagan Technology Metro • View topic - metro 6.22 can't assign program names
Postby niro » Fri Nov 12, 2004 5:41 pm
Notes:
metro 6.22, powermac g4, powerbook g4
Open "Program Names" (keystroke ctrl+n), click "New..." or "Edit...", and try to edit the program names in the dialog.
Click "Open...", open an .ins file, click "Edit...", and try to edit the program names in the dialog.
Writing a .ins text file manually still imports ok, but you still can't edit it from the "Program Names" dialog.
niro
Postby Jerm » Fri Nov 12, 2004 5:51 pm
I think this is user error. You should be able to edit them. Simply click on the "--" and wait for the edit box to appear.
Postby niro » Fri Nov 12, 2004 6:09 pm
this is totally not working on either of my machines. i'm running os 10.3.6 if that makes a difference.
niro
Postby niro » Fri Nov 12, 2004 6:13 pm
oh ok, single click. i was DOUBLE clicking on the double dash.
niro
