Sagan Technology Metro • View topic - metro 6.22 notation 1st ending crash
Postby niro » Sun Nov 07, 2004 3:53 am
Notes:
metro 6.22, powermac g4, powerbook g4
Consistent crash EXC_BAD_ACCESS, one EXC_BAD_INSTRUCTION using 1st ending tool in notation window.
Repro steps:
1. launch metro
2. enter some note data in "Graphic Editor"
3. open notation [keystroke command+shift+n]
4. pick "1st ending" from the barlines tool
5. click and crash
The consistent crash:
Date/Time: 2004-11-07 00:46:00 -0800
OS Version: 10.3.6 (Build 7R28)
Report Version: 2
Command: Metro G4
Path: /Applications/Metro-G4-6.22/Metro G4.app/Contents/MacOS/Metro G4
Version: 6.2.2 (6.0)
<<log deleted by Jerm>>
niro
Postby Jerm » Sun Nov 07, 2004 8:39 pm
This problem has also been corrected.
