Sagan Technology Metro • View topic - velocity tool doesn't work note view
Postby niro » Sun Nov 07, 2004 2:27 am
Notes:
metro 6.22, powermac g4
In the Graphic Editor, Velocity tool doesn't work in note view. It does work in drums view.
Repro steps:
1. launch metro and make some notes in Graphic Editor
2. click the velocity tool
3. you can only drag a note (or selected notes), not change the velocity values
niro
Postby Jerm » Sun Nov 07, 2004 12:19 pm
This works fine for me. I can easily use the velocity tool in note view and it works fine.
Thanks for the other bug reports I will be looking into them in the near future.
