Sagan Technology Metro • View topic - Problems with rendering audio
Postby Paul » Sat Jul 17, 2004 1:47 am
Two problems when rendering:
1: the song contains tempo changes. I render an entire track that contains an AU-synth that uses an arpeggiator. These tempo changes are not there in the rendered file. The arpeggiator in the audio file plays back at the tempo of the first bar. When playing back the original track (so no rendering took place), the arpeggiator follows the tempo correctly.
2: When I render part of a track (with an AU-synth that uses an arp), the midi notes of that part of the original track are gone.
Paul
Postby Jerm » Sat Jul 17, 2004 11:56 am
We are looking into this. What is the AU that you are rendering with?
Postby Jerm » Sat Jul 17, 2004 2:45 pm
This is fixed in 6.2.1.5
Postby Paul » Sat Jul 17, 2004 2:49 pm
Access Virus Powercore and ReFX Vanguard
Paul
Postby Jerm » Sat Jul 17, 2004 8:53 pm
There was also an audio overview display bug with tempo changes that is fixed in 6.2.1.5 :oops:
