Sagan Technology Metro • View topic - Stereo out on Internal-1
Postby Scoot » Fri Mar 12, 2004 8:11 pm
- Bring in an audio track into metro.
- open plugins and effects window and drag across AUMatrixReverb for example.
Should the Stereo Out above the name of the plugin read Internal-1 or Built in Audio-1?
The audio track in the sections window still reads Port: built-in audio controller.
If I allocate the track to an output it changes the effects window setting from Int to Built in.
Is this just metro's automatic selecting?
