Sagan Technology Metro • View topic - Recording with Notation window open could cause a crash!
Postby Jerm » Fri Oct 24, 2003 10:49 pm
There is a bug in Metro version 6.1.0.3 and before that could cause a crash if the notation window is visible during recording of MIDI data. To avoid this make sure to close the notation window while recording or get 6.1.0.4 when available.
