Sagan Technology Metro • View topic - SMPTE/Bar display bug
Postby axnyslie » Sun Oct 19, 2003 5:17 pm
I'm having a continuous problem where Metro is getting corrupted to where it puts itself in SMPTE Display mode and won't switch back to Bar Display mode in OS 9. The only fix is to delete the preference file and reregister but it eventually gets corrupted again and I have to redo the process whick is a big PITA.
axnyslie
Postby Jerm » Sun Oct 19, 2003 7:24 pm
Joe,
What version of Metro? OS 9.0, 9.1 or what?
Are you saying the command-D does not switch back to bar display? Is it repeatable such that, for example, it starts happening whenever a certain file is opened?
Postby axnyslie » Sun Oct 19, 2003 8:01 pm
Version 6.0.8.2 Metro with OS 9.2.2
Command+D will not switch it back. It usually happens with Audio tracks not with MIDI
axnyslie
Postby Scoot » Sun Oct 19, 2003 9:09 pm
would axnyslie's high sample rates cause any problems for metro?
or if they were mixed in the same composition?
Postby Jerm » Tue Oct 21, 2003 1:31 pm
I would need more specific information to figure this out. In other words I need a way to repeat it here.
