Sagan Technology Metro • View topic - Quicktime notes sticking
Postby Jazzdude » Sat Oct 18, 2003 7:39 am
I'm using Metro prerelease 6.1.0.2 and having trouble with the internal notes getting stuck on. Sending a command for all notes off or all sounds off does not turn the notes off.
Jazzdude
Postby Jerm » Sat Oct 18, 2003 10:16 am
If you are using a sustain pedal and quicktime instruments... :idea: you should send the bug report to Apple. Or perhaps they fixed it in 6.4. I haven't tested that yet. How come you are not using the DLS synth?
Postby Jazzdude » Sat Oct 18, 2003 12:13 pm
I recorded the data with an external synth. No sustain pedal data that I recall, but pitch wheel and modulation data are there. I haven't downloaded Quicktime 6.4 yet. I'll have to do that.
My first experiences with the DLS synth and earlier versions of Metro 6 were'nt great (crashes, etc. when loading some soundfonts). I'll have to give it another test drive.
Jazzdude
Postby Jerm » Sat Oct 18, 2003 12:24 pm
Well that is true Jazzdude. Some soundfonts still crash the Apple DLS player but as soon as you find a good soundfont (and most are) you should be able to run crash free.
