Sagan Technology Metro • View topic - Windows in the dock
Windows in the dock
Windows in the dock
Postby Scoot » Thu Aug 28, 2003 10:48 pm
I have 2 windows open - graphic editor and the mixer but this actually works with any combination.
If I quit and relaunch metro they are both there.
If I put one of then in the dock, quit and relaunch metro they are both still there.
If I put them both in the dock and quit and relaunch metro they are nowhere to be seen. This seems to happen if I have 4-5 windows open and they're all in the dock.
The transport window is on "float" if that's an issue.
In fact if I turn it off and save preferences it comes back floating again.
Does it always float now? (unless closed :-))
Postby Jerm » Fri Aug 29, 2003 1:09 am
The transport only floats if the float transport switch is checked.
Postby Scoot » Fri Aug 29, 2003 1:41 am
Yes.
The problem I've got is I can uncheck it, save preferences, restart metro and its on again.
Surely if preferences are saved it should remain off.
The window problem was found by mistake......well I was clearing the desktop area and threw every window of metro down into the dock and in that position quit the program.
Postby Jerm » Fri Aug 29, 2003 1:48 am
Okay I understand. I will take a looksie. It is likely that it is not saved with prefs and this is a bug.
Note that unfotunately this will push back the pre-release.
Postby Scoot » Fri Aug 29, 2003 4:34 am
Jerm wrote:Note that unfotunately this will push back the pre-release.
I'll shut up. :lol:
Can we have a sneak peak at the shaded midi graphic editor?
