Sagan Technology Metro • View topic - song number in the " sections " window
Postby françois » Sat Jun 14, 2003 12:04 am
When you have a lot of songs ( 530 ) in the left column with the number of songs, you only see you have 30.. you don't clearly see the left number... :idea:
Postby Scoot » Sat Jun 14, 2003 4:03 am
what happens if you have a smaller font size?
maybe metro only has two digit capacity or doesn't have a big enough margin to hold the extra information.
530? You running a radio station? :)
scoot
Postby françois » Sat Jun 14, 2003 4:20 am
with a smaller size, it's the same ...
and we can't make larger columns, the long titles can't be seen fully
it's certainly a margin trouble
I'm not running a radio station but I work I live sessions since 15 years, and I'd got a lot of floppy disks, and now with metro it's the musician paradise on hearth ....
:P
Postby Jerm » Sat Jun 14, 2003 10:50 am
This is a known problem.
Postby Jerm » Mon Jun 23, 2003 11:40 pm
This bug is fixed in 6.0.8.1
