Sagan Technology Metro • View topic - "Section Event Editor" window will be closed.
Postby TAUL » Tue Jan 05, 2016 7:28 am
Hallo Jeremy,
The window is closed in some situation ...I think It is several years after I watched it.
For example, the cases that dragged a mouse on the (number-input-box of) some dialogue windows.
I wanna keeping open the window to confirm changing tempo value, and I set so.
I use Metro 7.2.4 with Macmini mid 2011 and MacBook Pro 15' late2013
Does it appear on your environment ?
Thanks for supporting.
TAUL
TAUL
Re: "Section Event Editor" window will be closed.
Postby Jerm » Tue Jan 05, 2016 1:13 pm
Hello TAUL,
I cannot repeat this problem. Can you give the exact steps please?
Postby TAUL » Fri Jan 08, 2016 8:05 pm
Thank you replying,
OK, I want to attach the capture movie, but that is over capacity of this thread.
Could you guide me to mail for you?.
TAUL
TAUL
Postby Jerm » Sat Jan 09, 2016 4:16 pm
You can try to send it to info_AT_sagantech.biz where _AT_ = @. There is a limit on the size there as well so I hope it is not too big.
Postby Jerm » Mon Jan 11, 2016 2:52 pm
This problem has been addressed and should be fixed in the next point release.
