Sagan Technology Metro • View topic - An OSX audio bug - knowledge base document - easy fix.
Postby Scoot » Fri Apr 25, 2003 7:45 am
http://docs.info.apple.com/article.html?artnum=25446
Basically says quit any audio programs before disconnecting or turning off USB and firewire devices or the audio application may unexpectly quit.
10.2.4 and up.
Postby Jerm » Fri Apr 25, 2003 12:50 pm
Hopefully they will fix this next point release!
